It seems that the round trip is successful:
http://sketchup.google.com/3dwarehouse/ ... 2c30e19543
If you download the file and render it and see something similar to the logo image I added (or actually the test render one attached below), then it works for others, too.
(And yes, I am supposed to see this I guess, you just never know what uploading to the WH strips off the models...)
Twilight to 3D Warehouse - back to Twilight Test
- TL2WHTest.jpg (104.92 KiB) Viewed 5976 times
Gai...
Re: Twilight to 3D Warehouse - back to Twilight Test
Works fine. Perhaps people could start using "twilight ready" tag for models that can be rendered without modifications.
I've tagged it with "Twilight Render" (for simple "twilight", a bunch of scary things came up )
But there can even be some convention for this (as well as maybe some way to make sure that library and global material settings also travel the journey - as I am afraid, currently that is not certain as they need external reference)
Gai...
Tagging with "Twilight Render" should be sufficient enough/standard enough. Thank you.
Any hi-res images, sky images, IES files, etc. will not of course 'travel' with your warehouse-hosted model... but these are not needed to get great renderings.
Thanks for reminding us of this 'feature', Gai!
