Round corners render effect?
Pixero
Post by Pixero » Thu Oct 15, 2009 6:46 am
Would it be possible to add a round corners render effect like with MentalRay for Max?
Re: Round corners render effect?
Post by Fletch » Thu Oct 15, 2009 10:33 am
this would be the 'bevel' feature in Kerkythea, I presume, and yes you will likely see this in a future version of Twilight when a more advanced material editor will be developed.
Gaieus
OS: Win XP + SP3
SketchUp: 6 7 8
Post by Gaieus » Thu Oct 15, 2009 3:39 pm
Hi Fletch,
I have never had any success with this feature in Kerky. Does (should) it really work?
BTW sometimes it's still better to model this effect as we may not necessarily need every edge with a certain material rounded/bevelled)
Gai...
notareal
Post by notareal » Thu Oct 15, 2009 4:08 pm
Gaieus, it does work in KT. Just take a simple KT basic primitive, cube, and play with it.
Gaieus
OS: Win XP + SP3
SketchUp: 6 7 8
Post by Gaieus » Thu Oct 15, 2009 5:14 pm
OK, sorry, I should have made it more precise. It did work for me with KT basic primitives but I couldn't get it to work with exported SU models. And "as if..." I'd read later, on the KT Forums, that it indeed doesn't work with SU models (in that case, I guess the exporter also has some limitations with the model).
Gai...
Post by Fletch » Thu Oct 15, 2009 5:58 pm
I believe you have to 'weld' the SU exported model... and it was the welding part that was "wonky" - not to put too fine of a point on it.
notareal
Post by notareal » Thu Oct 15, 2009 6:46 pm
If you export as .obj it should work. Not sure if SU2KT got fixed, so that vertex welding is properly done. But if the model is correctly build, KT can "bevel" it just fine. Keep in mind that it's a visual effect, like bump. Geometry is not modified.
Gaieus
OS: Win XP + SP3
SketchUp: 6 7 8
Post by Gaieus » Thu Oct 15, 2009 7:11 pm
Yes, of course, I understand it's a visual effect (although maybe rather comparable to displacement as it looks like geometry is modified not simply shadow effects added like with bumps).
OK, I will play around with welding vertices. In the "WIP Gallery" I posted some clay renders of a project I am working on. Round edges are already a big difference and I guess, when it's also textured, it will looknice with the texture subtly running around on those small but visible round corners.
I'll try to get as much out of this project as I can. ;)
Here is a short video I experimented with (I amplanning to make similar effects in a final video rendered).
http://www.youtube.com/watch?v=eSGfovQrIwI
Gai...
Post by Fletch » Thu Oct 15, 2009 9:55 pm
I personally would just use the bevel by Fredo - I'm actually falling in love with that plugin/combo with Twilight - it's such a powerful modelling tool! (I've use it for roofs, and everything.)
Pilou
Post by Pilou » Thu Oct 15, 2009 10:49 pm
But does not multiply polys and increase time render?
Pilou (Frenchy)
Is beautiful that please without concept!
Speedy Galerie
