Your move.
- SketchUp: 2014
Your move.
I did this wobble chess board a while back and decided to render it last night.
The design is not mine but I did model it.
- Wobble02.jpg (429.82 KiB) Viewed 12329 times
Re: Your move.
excellent!! I recall seeing this board before, very nicely done......but fred please......round edges on table!!!
i like the splash of colour from the lights
Oli
- SketchUp: 2014
Re: Your move.
Yes I did this with Podium a year or so ago. However for this one I completely re-vamped the board. The Podium render was very low poly and this one is already over 50,000 polys. A big oops however, while smoothing it out I got the light and dark squares mixed up and the board is not correct. Oh well. I'll fix it if I do another render.
About the table, yes I guess I should round those edges a bit, thanks. I guess I was more focused on the board. It is the little things I always miss.
Re: Your move.
That's why we are here to whip your ass heheBoofredlay wrote:It is the little things I always miss.
Oli
Re: Your move.
Hum hum
It's not a cheackboard!
Case on the right under pieces must be white
- SketchUp: 2014
Re: Your move.
Ok, I updated the board, smoothed some edges, added a base to the chess board to give it some weight and changed the chair.
Whatcha think?
Whatcha think?
- Chess06.jpg (440.23 KiB) Viewed 12089 times
Re: Your move.
I am affraid that you must make another render
Pieces are not on the good side
In classical play King is always the bigger size and has the cross (so it's good) so your first play is E2 E4
And at the start the Queen is always on its color!
But see your image it's D2 D4 !
It's very pertubating for a chess player (chees player)
You can answer that is a retrograde analysis problem but I doubt that is that you want make
And don't know if this position has a solution
ps I understand your error of the first post: original had the same
Re: Your move.
thats so much better. the rounded edges look great, adds more interest too.
I think you need a little more contrast in the image maybe and perhaps the chess board would have more reflection?
Oli
- SketchUp: 2014
Re: Your move.
Sorry about the crit, I didn't mean to offend if I did....I thought you may want constructive feedback. Sometimes people take it the worng way...
I did do a quick PP to show you what I meant but I reverted back to original by mistake without saving
Which template did you use for wood table? looks v nice although I would a touch more bump.
I have a method for adding these sly wood 'scratches' to the bumpmap here:
http://twilightrender.com/phpBB3/viewto ... f=13&t=597
Oli
Users browsing this forum: Bing [Bot] and 2 guests
