The original tga is embedded in the SKP.
It gets exported to the temp directory when rendering.
Twilight handles tga, it just doesn't recognize that they have alpha transparency. The next version of Twilight will add tga to the list of images to allow alpha for.
Trees as Black surfaces
Re: Trees as Black surfaces
As nothing works for me, Ecuadorian Kerkythea export, Chris Temp file...
I have found more simple
Just draw a rectangle filled with texture of Color Picker of trees' leaves
Edit texture et voila I can extract easily an image tga from the 3Dwarehouse SU file
- idea.jpg (78.26 KiB) Viewed 6052 times
Have you seen this video tutorial using this exact tree that I made, Pilou?
Now yes
Tricky indeed
And waiting the new Tga support for avoid all these manipulations
Tricky indeed
TGA support now provided... give it a try (see the "news" section of the forum for the latest download)!
