Processing had errors...
- SketchUp: 2014
What would cause this message?
I created a model earlier today, sent it home via gmail then opened it a few min. ago to render. Everytime I try I get a "Processing had errors.." message.
I have purged, saved, reopened etc... The file is only 588kb.
- SketchUp: 2014
Re: Processing had errors...
Ok, sorry for not enough info...
I am running SU 7.1 on both machines. I did some preliminary renderings at work before I sent it home and it ran fine.
Now that I have it at home it will not respond. I did not tweak anything, just opened and hit render.
This has happened to me when Twilight isn't able to locate an external texture. It will still render, but will present that error message.
- SketchUp: 2014
Hmm. I thought that was it after reading your reply however no go. I stripped the model of it's textures, purged, saved, reopened and got the same result.
I just copied the components to a new file and it is working now so the one sent from the office must have been corrupted somehow.
did you use the copy>paste keyboard shortcuts to copy them to a new file?Boofredlay wrote:I just copied the components to a new file
- SketchUp: 2014
Things like missing textures, missing IES lights, missing background images can cause that message to appear. However, in most cases it should still render, with at worst a black material. I'm very surprised to see it not rendering... If you still have that file laying around, I'd like to see it.
- SketchUp: 2014
I will send the offending file to you tonight Chris.
- SketchUp: 2014
Well I cannot upload more than 250kb in a PM so I cannot send it to you Chris.
However, I have a theory as to why it is happening. I have to check my work machine tomorrow... trying to keep up with two machines sucks.
Rapidshare it.
