Best Of Tips and Tricks - The Master List - V1.x
Posted: Sun May 23, 2010 1:15 pm
Now grouped for easier browsing:
Modeling Tips
Modeling Tips
- Sharp corners = unrealistic
- How to fake fire flames
- Photomatch - Aligning a Rendering with the Original Image
- Front Face Tool by Tomasz
- Curved Surface Textures in SketchUp
- Complex UV Mapping using Proxy Object in SketchUp
- Hidden Layer Visibility in Components (aka Proxy Objects)
- Liquid In A Glass - How To Model Wine or Water - by Massimo
- Shag Carpet - Shaggy Carpet - Furry Rug
- Material and light settings
- Realistic Water - Fast - in Twilight Render
- Force a background image to render unaffected by lighting
- Editing a Leaf Material in Kerkythea
- Curved Surface Textures in SketchUp [VIDEO]
- Copy colors from anywhere with hex color codes
- Smooth Transparency Gradient
- How to render dirty glass and other contaminants - tutorial by Sergio
- How To Render Edge Lines (wireframe) Only
- Complex UV Mapping using Proxy Object in SketchUp [VIDEO]
- Reflections in Architectural Glass
- Materials on Back / Reversed Faces and UV Tools Fix
- How to render an invisible wall for a building section in Twilight Render
- Pool Water at night
- Basic Light and Lighting Terminology in Rendering
- Diagram of a Spotlight
- Soft Shadow Radius for Sun, Spot, Point Lights IN DEPTH
- Light Emitter v. Spotlight in a downlight (can light)
- Color of Lights / Light Render Speed Comparison
- Pointlight or Spotlight vs Light Emitter Material
- Light Emitting Surface Options
- Lights - render times...
- Lighting Made Simple
- Jewelry and Product Shots - the Right Light a.k.a. "photo studio" "lighting studio"
- How to make concealed light on ceiling - a Cove Light or Recessed Soffit Light
- Light Bulb - aka "Come on, baby, light my bulb!"
- Interior Renderings - Exposure for Background Outside
- Reflection of Lights in surfaces
- Realistic Lighting Color
- Lynda.com Spot Light and Projector Light Video Tutorial
- Night Shot - Exposure and Lighting
- Moonlight Effect with Twilight's Physical Sky
- Default Sky Setting for Twilight... and speed up SU
- Scale an HDR Spherical Image to Match Your Scene (How To)
- First thing to do to warm up the Sun and Sky
- Physical Sky in Twilight Render
- Bye-Bye Blue Sky
- Prefer a crispier look? Try alternative antialiasing methods
- Render Settings - the Best One
- How to Modify Twilight Render Settings
- Easy 1-7 Photon Mapping and Final Gather (Biased)
- Progressive Rendering (Unbiased Method)
- How to use Twilight with SketchyPhysics
- Making a movie - I have these images, now what?
- Render Quick Test Animation from SketchUp
- Animation Setup Tutorial Video
- Animation sequence to H.264/MP4 video (Video Size, Video Codec, Video Compression
- You already have a bigger version of your "Interior" render
- How to get DOF (Depth of Field) in your image [Video]
- How to render a section / Cómo renderizar un corte
- Calibrate your Monitor
- Resume / distribute an interior progressive rendering
- Recover Temporary Image after Crash
- Getting Started Basics in 3D Rendering
- NPR (Non-photo-real) render using SU+TWi
- Bye-Bye Blue Sky
- How to use Alpha Mask render pass in Post Production
- Background Image / Picture Using Alpha Mask
- Making Fog Using Depth Render Pass
- Background image with Gimp for interior - Video
- Shadows effect with Gimp(To cast a shadow on an invisible ground plane)
- Using Kerkythea Material Editor with Twilight
- How to use materials and material libraries from Kerkythea?
